Thread: DWA Standard Sizes?
    Default DWA Standard Sizes?
    Is there any way to have a Door Window Assembly Style with standard sizes listed? Any work arounds to make this possible?
    I could stop if I wanted to neje's Avatar
    2002-12
    234
    Default Re: DWA Standard Sizes?
    what happened to the NG for asking general questions for ACA/AMEP? There seems only the specific NG's now???
    I've had the same problem and resorted to using ME's to create custom window shapes that follow specific brick sizes. I've found for windows I strip an Awning windows (set frame to 0) and use it as the inserted block and then it displays correctly. (Or a slider or a casement etc.) ME is window style so it folllows same material setting. I've not done it for a door frame but I guess could do the same but I do just use regular DWA's and adjust size. Windows are used much more often!
    Thumbs up Re: DWA Standard Sizes?
    Thanks very much...I'll give it a try. I figured someone must have tried to find a way around this.
    OK....it's taken me a while to find time to try this out.
    I made some ME's for the custom frame profile and inserted a separate frame for each side and top and bottom. This way when the window is resized the frame lengths stretch but the profile width remains the same. All works fine except for the lines that show where the frames cross at the corner (see attached screenshot).
    Any way to get around this? Of course if you join the frames before inserting the corner gets cleaned up but then the frame widths get distorted as the window is made larger or smaller.
  1. 2011: Nominal Pipe sizes Standard vs Metric
    By JLHConsulting in forum AutoCAD General
    Last Post: 2011-02-17, 07:18 PM
  2. Standard Paper Sizes vs Print Areas
    By gfreddog in forum AutoCAD Plotting
    Last Post: 2011-01-20, 07:33 PM
  3. Automatically converting non-standard DWGs to standard DWGs
    By chillme1 in forum AutoCAD Customization
    Last Post: 2006-12-18, 04:47 PM
  4. Replies: 2
    Last Post: 2006-04-28, 11:17 AM
