Thread: IFC - how to export length instead of cut length on framing
    2011-05
    5
    Default IFC - how to export length instead of cut length on framing
    Hi im trying to export steel structure to SCIA Engineer 2009 via IFC 2x3,
    the problem is framing (beams and bracing) are exported as physical model instead of analytical. So instead of joining the column in the analytical point all the beams hang in the air. Check out the screenshot i attached to this forum.
    There are no options on the Engineer side so i have to modify the IFC settings (mapping etc) on the Revit side.
    Anyone has some suitable IFC Class Mapping file or default template for IFC?
    2012-01
    3
    Default Re: IFC - how to export length instead of cut length on framing
    Hi I'm in same situation. I'm trying expor a model to a FEM szoftver (Axisvm) via IFC.
    The architectural modell is exported correctly, but the analytical members and loads is fully missing.
    Can anyone link a correcly IFC export classes in txt for analytical export?(Revit structural 2012)
    I found the template files, but it does'n content the analytitcal modell classes.
    Thanks
  1. Replies: 1
    Last Post: 2010-04-06, 03:27 PM
  2. Arc length??? Any way to draw to an exact length?
    By fhoffnar in forum AutoCAD General
    Last Post: 2007-10-15, 02:21 PM
  3. Draw an ARC by length, not cord length
    By melanie.santer in forum AutoCAD General
    Last Post: 2006-03-21, 03:35 PM
  4. Cut Length of stuctural framing
    By E-Key in forum Revit Architecture - General
    Last Post: 2005-12-05, 03:59 PM
Tags for this Thread
