Thread: AutoCAD 2010 Re-install Help
    2010-07
    29
    Default AutoCAD 2010 Re-install Help
    hey guys i need some help, I have stand-alone AutoCAD 2010 install in my PC then my PC needs reformat so my IT reformated it & then i try to reinstall my AutoCAD but the problem it appears this when im trying to re-activate it "The serial number you entered is not valid. Try again. (1)" what is the solution for this do i need to contact Autodesk for a new serial no. so i can get the new activation code or there is simple solution for this...
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,285
    Default Re: AutoCAD 2010 Re-install Help
    Quote Originally Posted by jomzcruz View Post
    The best bet will be to contact the reseller you purchased your software from or Autodesk.
    My perspective on the error is that it could be a typing error when inputting... there might be other messages like it could not authorize the number automatically because it's been authorized two or three times already, in which case they'd do so manually.
    Or, perhaps just a confusion between which serial number belongs to which product... I had some LT seats and a full seat, and accidentally tried to authorize mine with a serial number from the wrong product, so it was rejected. ~facepalm~ (I keep my S/N for all software and equipment in a spreadsheet, so I can copy/paste them when needed, and always know where they are).
    Best of luck getting activated.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  2. Can I not install 2010 32 bit on a 64 bit OS?
    Last Post: 2009-05-28, 03:07 PM
  3. Revit MEP 2010 Install Problems
    By bdavis.216450 in forum Revit MEP - General
    Last Post: 2009-04-30, 02:50 PM
  4. 2010 Vista Install Failure
    By jayc in forum Revit Architecture - General
    Last Post: 2009-04-28, 01:41 PM
  5. revit 2010 install
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-04-27, 07:47 PM
