Thread: Project Browser Organization
    I could stop if I wanted to antman's Avatar
    2006-10
    Highlands Ranch, CO
    418
    Default Project Browser Organization
    I am working on a custom project browser organization, and it's mostly working well, but I've hit a snag. What I have done is this:
    Created a project parameter (instance / text / identity data category) named View Category.
    Created a view template for each type of view (this was the only way I could see to have a preset list available so users wouldn't type in values).
    I can now either set a view current, or select one view in the project browser, and select a value for View Category in the properties palette.
    If I try to select multiple views and enter a value, it applies it to my current view (or, if I am currently in a sheet, nothing happens).
    The way I can get around this is to temporarily duplicate all my view templates and set View Category to be the only item the template includes. I'd rather not have to do this for around 30 view templates total. Is there any other way to assign a value to the instance parameter of multiple views at once?
    Anthony Mason
    CAD/BIM Manager
    Daily Occurrence
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Project Browser Organization
    Try creating a view list, which includes the parameter.
    You can probably manipulate the parameter value faster there...
    2006-10
    Highlands Ranch, CO
    418
    Thanks to CAD Masters tech support (you guys rock!) I have a solution. File this one as a Revit bug that hopefully gets fixed in the next update or release. The 'problem' is that I'm using a Windows 7 Aero theme. If I switch to a standard Windows theme, I am then able to apply the value to multiple views at once. Not a horrible workaround once you know what to do, but I would have never thought of that...
    Anthony Mason
    CAD/BIM Manager
    Daily Occurrence
    2011-05
    29
    Quote Originally Posted by antman View Post
    Wow. Seriously - wow. This had been driving me nuts, and I can't believe that THIS is the solution. CRIPES.
  1. project browser organization
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-01-12, 05:00 PM
  2. Project Browser Organization
    By greg.gebert978266 in forum Revit Architecture - General
    Last Post: 2008-06-03, 04:36 PM
  3. Project Browser Sheet Organization
    Last Post: 2008-05-28, 01:00 PM
  4. Project Browser Organization
    By jaroguy in forum Revit Architecture - General
    Last Post: 2006-09-25, 05:53 PM
