How do I set the default view template for default views? Thanks.
For views already created, look at the last line of the Identity portion of the view properties: Default View Template. You can set it there. And when you go to apply a view template to a particular kind of view, there's a check box for "Apply automatically for views of this type". For every view template you create, also create a view type that uses that view template. The limitation appears to be for plan views, where it doesn't seem possible to make an Enlarged Plan view type, for instance.
I can't get the scale to come through when i check the 'apply..' box. All of the other properties are applied, but not scale. But if I re-apply the view template (that's already assigned to the view) the scale will come through. Why is that happening? Thanks.
