All,
I have a particular lisp routine that when loaded and run causes the title of the VLIDE Text Editor to display the file name and "loading" (see atached image).
Anyone seen this before?
Thanks as Always,
Jeff
All,
Thanks as Always,
Jeff
Hi .
If you show the code we may could show some light of it .
Regards
I editted the code and found that it was the use of the "Close" command in the routine that causes the issue. It will lock the VLIDE text editor so that you can't edit the lsp file. This is true even after you close both VLIDE and AutoCAD. I had to restart my computer to get it to clear. After taking the "close" command out, it runs as expected.
Thanks for the reply Tharwat.
Jeff
Again, without your source code, I cannot know for sure, but this code snippet may be of use to you.
Edit: You might also look into the vla-close Method in the Developer Documentation.
Computer Specs:
