Thread: Degrees symbol in text
    2005-07
    Melbourne, Australia
    93
    Default Degrees symbol in text
    Is there any way I can insert degrees symbol (for angles) in text. In AutoCAD it is a simply matter of typing%%D, however this doesn't seem to work in Revit. It works for angled dimensions.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    1 members found this post helpful.
    Default Re: Degrees symbol in text
    You can either copy and paste the symbol from Character Map....
    Or...
    Use Keystroke: Alt+0176
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink or :whiskey: or :wine:"
    2005-07
    93
    Thank you Michael, you are a champion, something so simple I could kick myself. I searched the help documentation to no avail, however your second option worked a treat. I guess there are other secrets for the other %% symbols from AutoCAD that could be applied to Revit. I will certainly investigate these.
    Thank you very much for your assistance
  1. 2011: Text orientation at 270 degrees
    By rgarthe1 in forum AutoCAD General
    Last Post: 2010-08-25, 07:31 AM
  2. How do I enter the degrees symbol - 'o'
    By ukdodger in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-10-08, 05:40 AM
  3. Table: Rotate Cell Text 90 degrees
    By ameador in forum AMEP General
    Last Post: 2007-10-05, 07:47 PM
  4. Replies: 6
    Last Post: 2006-10-11, 01:21 PM
  5. dimension text rotated 180 degrees
    By jkipfer in forum AutoCAD General
    Last Post: 2004-07-23, 05:24 PM
