harrymckinney
I am working on a tutorial using Navisworks Animator. I have created a scene and added a camera. I have moved the Time Bar and captured key frames to animate the movement of the camera through the building. When Played, the animation works correctly, with the camera following the path I chose. Then I added an animation set (opened a door) in the same scene. Now when I Play the animation scene the animated set works properly, with the door opening as animated. However, the camera remains stationary. When I deactivate the animation set (door) the camera moves through the building properly. What am I doing wrong that prevents the camera animation and object animation from working simultaneously?
