Thread: annotation rotate with object
    2003-01
    194
    Default annotation rotate with object
    I inserted some parcels and centerlines using mapimport. I labeled them with map annotation but they all came in horizontal. Is there a way to have them align with the centerline?
    South Eastern US, exact location unknown
    1,376
    Default Re: annotation rotate with object
    Yes, in the template when you create the expression you can use the angle property from the objects (lines & plines).
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
  1. Structure rotate according to object
    By WScottAllenPE in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-11-14, 12:01 PM
  2. copy rotate object multiple times
    By gary.betts in forum AutoCAD Mechanical - Wish List
    Last Post: 2009-03-09, 12:36 PM
  3. Rotate inserted OLE Object?
    By stephen.coff in forum AutoCAD General
    Last Post: 2007-10-11, 01:34 PM
  4. rotate an imported dwg object
    By p.vicini in forum Revit Architecture - General
    Last Post: 2005-03-28, 12:40 PM
