Results 1 to 6 of 6
Thread: Construction Line Snap Issues
    2009-05
    10
    Default Construction Line Snap Issues
    Not sure if anyone has experienced this, but every now and then I get this problem when I cant snap to the intersection of a construction line and another line, whether its a normal line, poly line or another construction line.
    I'm having this problem atm while drawing up room elevations. My snaps are on (Endpoint, Midpoint, Center, Node, Quad, Intersection & Extension) and I had no problems yesterday or earlier today, like right after I finished one elevation I tried starting the next and this problem occurred.
    Restarting the drawing and autocad haven't worked so I'm a little lost on what has happened.
    Anyone have any advice or help I would really appreciate it
    Cairo - no, not Illinois
    4,626
    Default Re: Construction Line Snap Issues
    does the osnap APPINT work in those instances? possbile different z values/planes ?
    2009-05
    10
    Wow, never even looked at that option, thanks! It was caused due to the lines being on a different z value.
    Is there a fast way or even a few commands that will ensure all linework is on the same z value rather than changing the value through the properties menu?
    0,0,0 The Origin
    8,569
    Make sure OSNAPZ is set to 1 and ELEV is set to 0.
    (but set OSNAPZ to 0 when/if you work in 3d)
    John B
    2017-12
    I have tried the recommended solutions, but nothing seems to work for me either. My problem is that drawing a new line, or pline will not snap to any part of construction line. Any thoughts. I have togged all osnaps, checked the osnapz settings, and z plane values, but to no avail. Thanks
    Houston
    9,397
    Quote Originally Posted by rob761069 View Post
    Are your "construction lines" a line, or polyline, or ray, or Xline, or something else?
    Objects on layer DEFPOINTS are not select-able when layer 0 is frozen. Probably not your issue, but worth throwing out there.
    R.K. McSwain | CAD Panacea |
  1. Allow you to snap to a line even if you are at a gap in the line type
    Last Post: 2014-10-22, 07:20 PM
  2. construction line issue!
    By shifra972412207 in forum Streamline - General
    Last Post: 2013-08-19, 08:51 AM
  3. Construction line projection
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2012-08-03, 12:31 PM
  4. Construction Line linetype
    By n.g in forum Inventor - General
    Last Post: 2007-04-30, 04:58 PM
  5. Snap Bugs (moved from Known Issues...)
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2003-07-11, 11:25 PM
