Thread: Data linked Excel table formatting
    2007-02
    12
    Default Data linked Excel table formatting
    Hi all!
    I recently decided to see how the AutoCAD tables work. I was very happy to learn you could link your Excel spreadsheets with CAD. But now I have a problem.
    After inserting the table it refuses to use the table style I have set up. The fonts do not want to change at all. I can change the colour of the text, but not the font.
    Any suggestions.
    PS: Using AutoCAD 2011
    Moderator BlackBox's Avatar
    2009-11
    2,401
    Default Re: Data linked Excel table formatting
    Once you've used Paste Special to add a linked, AutoCAD Entity (read Table) from Excel, you should be able to select a cell, and change the font in the Properties Pane (Ctrl+1 if not shown).
    To change multiple cells at once, simply select the first cell, then Shift+Select the last cell in a given range (as you would in Excel).
    Hope this helps!
    "Potential has a shelf life." - Margaret Atwood
  1. 2011: suppress zeros in data linked excel table
    By ccowgill in forum AutoCAD General
    Last Post: 2011-06-14, 05:16 PM
  2. Excel Table Conditional Formatting
    By kwest in forum AutoCAD Tables
    Last Post: 2009-11-18, 05:28 PM
  3. Replies: 1
    Last Post: 2009-06-16, 09:39 PM
  4. Export data from a Table to EXCEL
    By brian.thomas in forum AutoCAD Tables
    Last Post: 2006-11-01, 12:51 PM
  5. Formatting of Numeric data when exporting Hole Tables to Excel in AutoCAD Mechanical
    By roger.brown in forum AutoCAD Mechanical - Wish List
    Last Post: 2006-02-10, 01:45 PM
