Thread: Converting Multiple Block Files
    2015-09
    420
    Default Converting Multiple Block Files
    Hello AUGI Members,
    Our company is in the process of migrating to AutoCAD 2012 running on a 64bit Windows 7 environment. I am trying to update thousands of our existing bock drawing files from AutoCAD 2009 to 2012 and was using one of my VBA scripts that allows me to open a folder of drawings (+/- 200 drawings) and performs a purge and save before closing each file.
    I start the process and while it is running move to another workstation to do some other work. What I have noticed is that the script stops working, for some unexplained reason, after approximately 70 to 100 drawings. I must then kill the VBA process to free up the workstation which in most case requires me to also kill AutoCAD.
    Please note that in our old configuration (AutoCAD 2009 running on a 32bit Windows XP environment) the script runs OK and processes al the files in the folder....!!
    Has anyone experienced this type of difficulty....?? Is there a better way to accomplish this task....??
    Your assistance will be appreciated....!!
    Best Regards,
    Vince
    Earth
    9,805
    Default Re: Converting Multiple Block Files
    I know this is not what you asked...but before going down this road.... I'm just wondering why you need to convert these drawings? Is it just for the purge or do you really need these to be in 2010 DWG format for some reason.
    R.K. McSwain | CAD Panacea |
    2015-09
    420
    These drawing files are block files that willl be inserted over and over into our new AutoCAD 2012 drawing files. I thought it would be a good to have all the components of our drawings (including blocks and Xrefs) and the new AutoCAD 2012 level.
    Vince
    Earth
    9,805
    There shouldn't be any issue inserting drawings saved as older versions. We still have a lot of blocks in older versions (even some R13/R14 format) that we use.
    If you really want to continue, have you looked into using ScriptPro ?
  1. multiple block redefine from other dwg files
    Last Post: 2015-07-27, 01:06 PM
  2. Converting multiple DWG files to older version
    By drdesignz in forum AutoCAD General
    Last Post: 2009-03-04, 09:32 AM
  3. Converting plot files to dwg files
    By tcone00 in forum AutoCAD Plotting
    Last Post: 2007-11-24, 04:27 PM
  4. Update Block Definition is multiple files.
    By dhendrickson in forum AutoCAD General
    Last Post: 2007-01-25, 05:56 PM
  5. Batch converting dwg files to dxf files?
    By CADKitty in forum AutoCAD General
    Last Post: 2005-08-09, 05:24 PM
