Hi all.
I am having big headache trouble =/
I am trying to create a connection clip angle - beam/column flange... I click at the function, I select the column and the beam, I configure my connection... but when I click on apply and ok... it moves my column and modify my beam in a way that the connection stay in the beam and in the "air"...
what am I doing wrong? what should I do to the automatic connection works?
ahhh I am trying to make a clip angle - beam/column flange connection but this is happening with all automatic connections available, including column base.
Second doubt....
I tried to create a "manual" connection... same style, clip angle - beam/column flange.
I´ve created the plate, bended it, put it on its place. so... I´ve click on the button "drill/bolt" to make the drills and place the bolts on the plate... I´ve configured the drills properties and clicked on the button "drill". and whereas I click, the bold appears parallelal to the plate, not crossing it. What should I do?
thanks for all
