I was just creating a garage slab that slopes & used the "ramp" to create it. I noticed that you cannot get a spot elevation from a ramp. Is it possible to slope a floor? or would one use a roof?
I was also creating a sloping garage slab but to a center drain. I created four different floor slabs, each using the slope arrow. The result was four triangular floor slabs with the correct slope and convergence point. I then placed an opening in the center but had to create it for each of the floor slabs to get the circlular drain opening. I tried to join the floors but was unsuccessful.
I would like a result that looks like I would get with a solid revolve. Smooth!!
Is there an easier way to do this?
An easy way is to use create an in-place void blend, with the base set at the waste outlet level and the top at the slab level. Start with a thicker slab than you need and cut the excess away with the void blend.
I'm fairly new to Revit and have not yet used the void blend tool. I will attempt your method today. Thank you for the suggestion.
I had a similar question some time ago. You may find this thread helpful:
http://forums.augi.com/showthread.ph...ht=slope+drain.
If for some reason the link does not work use the search tool and type in "slope to drain."
Beegee,
I,m sure your solution is simple and elegant, and I thought I had a handle on it, but after several hours of frustration I am at a standstill. Here's what I have done:
Constructed a floor 3' thick, just to have a thick floor to to see any changes.
Placed round opening in center>then to model tab>create>floors in Family Category and Parameters.
Void Form> Void Blend>set depth to -2'>select drain hole>Edit top>Depth to 0,0>lines>select edge of floor>finish sketch>receive error (Can't create blend).
I have looked at the selections in elevation and the drain selection always remains on the level one regardless of the numbers I assign to it.
What am I doing wrong??
Have you set the work plane to the appropriate position before making the blend ?
I tried that. Set to level one and since it's a floor used a negative number for the base(drain hole) and 0 for the top, which, are the slab edges. Still get the same error!!
Can you post a file - just the slab and void , for one of us to look at ?
