Thread: Properties Window Auto Apply Disable?
    2006-02
    High River, Alberta, Canada
    8
    Unhappy Properties Window Auto Apply Disable?
    Hi,
    I'm currently working with Revit MEP 2011 but this applies to all flavors.
    Is there a way to disable the "Auto Apply" feature when the mouse cursor is moved away from the properties window and back into the view window after you change the property of an element? It can be a very anoying feature at times!
    Cheers,
    2006-02
    8
    Default Re: Properties Window Auto Apply Disable?
    Steve Stafford replied to my post in Revit Forum. The auto apply can not be turned off.
    See the post here: http://www.revitforum.org/f9/propert...945/#post31494
    Cheers,
  1. 2012: Quick Properties - how do you disable
    By jschultz in forum AMEP General
    Last Post: 2012-02-17, 03:28 PM
  2. Disable auto-tagging (2011)
    By matt__w in forum Revit MEP - General
    Last Post: 2011-01-24, 09:18 PM
  3. Auto-apply View Template modifications
    By sthedens in forum Revit Architecture - General
    Last Post: 2009-12-23, 12:26 PM
  4. Disable Auto Refresh
    By david.metcalf in forum ACA General
    Last Post: 2005-04-09, 04:36 AM
Tags for this Thread
