Results 1 to 10 of 12
Thread: Command function in reactor
    2004-11
    21
    Default Command function in reactor
    I am attempting to write my very first reactor and am having a bit of difficulty in pulling off my desired intent. What I am trying to achieve just prior to a save or close event is the following:
    Save current layer to "0"
    run the TEXTTOFRONT and the HATCHTOBACK commands.
    I've had no problem with the first statement - but the last two are causing me some headache. Upon further investigation I have discovered that reactors disallow the use of the command function. Is there a way around this? I thought about redefining the Save and Close commands but this seems unnecessarily messy.
    Thanks ahead of time for any input. I am including my attempted code below.
    (defun VLR_DWG-IT ()
      (vl-load-com)
      (if (not *DrawingSave*) (setq *DrawingSave* (vlr-dwg-reactor nil '((:vlr-beginsave . DoThisBeforeSave)))))
      (if (not *DrawingClose*) (setq *DrawingClose* (vlr-dwg-reactor nil '((:vlr-beginclose . DoThisBeforeSave)))))
    (princ "\n*** ------ Save and Close Reactors Activated. ------ ***")
    (defun DoThisBeforeSave (CALL CALLBACK)
      (setvar "clayer" "0")
      (dwgcleanup)
      (command ".TEXTTOFRONT" "Both"
    	   ".HATCHTOBACK")
      (princ)
    (VLR_DWG-IT)
    2004-08
    Iron Station, NC
    3,198
    Default Re: Command function in reactor
    you cant use COMMAND when using reactors. I'm not sure, but you may be able to use the VL-CMDF instead.
    2004-11
    21
    Disregard the previous code - there was an erroneous call to another function that is not shown - below is the corrected code.
    Thanks again in advance for any help provided.
      (vl-load-com)
    	   ".HATCHTOBACK")
      (princ)
    (VLR_DWG-IT)
    2009-11
    5,719
    Quote Originally Posted by newfoundfreedom View Post
    ... You're missing the point.
    You CANNOT use Command calls with Reactors (specifically the CallBack function(s)).
    Consider using SSSetFirst + Ai_DrawOrder combo instead.
    Computer Specs:
    2009-11
    5,719
      (vl-load-com)
           ".HATCHTOBACK")
      (princ)
    (VLR_DWG-IT)
    Out of curiosity....
    Having looked at your Callback function more closely, why do you want to make changes to the drawing prior to Close?
    Wouldn't you end up saving those changes as well (potentially firing the :vlr-BeginSave event again), effectively repeating the Callback a second time?
    Just a thought; admittedly I've not tested your code. Perhaps I am mistaken.
    HTH
    Computer Specs:
    2009-11
    5,719
    As an example:
    ;;; Reactor function:
      (vl-load-com)
      (cond (*Reactor_BeginSave*)
            ((setq *Reactor_BeginSave*
                    (vlr-dwg-reactor
                      nil
                      '((:vlr-beginsave . saveCallback))))))
      (prompt "\n*** ------ Save Reactor Activated. ------ ***")
      (princ))
    ;;; Callback function:
    (defun saveCallback (dataBase fileName / _Send ss)
      (defun _Send (ss loc)
        ;; © RenderMan, 2011
        (sssetfirst nil ss) (ai_draworder loc))
      (if (/= "0" (getvar 'clayer))
        (setvar 'clayer "0"))
      (if (setq ss (ssget "_x" '((0 . "DIMENSION,MTEXT,TEXT"))))
        (_Send ss "_f"))
      (if (setq ss (ssget "_x" '((0 . "HATCH"))))
        (_Send ss "_b"))
      (princ))
    ;;; Autoload for named drawings:
    (if (= 1 (getvar 'dwgtitled))
      (VLR_DWG-IT))
    ;;; Silent load:
    (princ)
    Computer Specs:
    2004-11
    21
    RenderMan - thank you so much for your responses.
    - Response 1 - I didn't miss the fact that the command function couldn't be called within a reactor, I actually state that in my original post. However I was just trying to take out anything that might be confusing to someone looking at my code.
    - Response 2 - You are absolutely correct about not needing the reactor to run on a Close event. Honestly, I'm not even sure what I was thinking here.
    - Response 3 - Thank you so much for your code corrections. This is educational to me on a number of levels.
    First being the "sssetfirst" function. I have never run across it before.
    Second the way you are wrapping even simple statements like setting the current layer within an if statement. It never occurred to me to test for the current layer prior to resetting it. I like your thoroughness!
    Third - I really like the dwgtitled test at the end as well.
    A genuine thanks for all that.
    Now heres the problem. As much as I dig your code corrections - I'm having trouble getting it to work. It loads up just fine - but when I actually run it on a test drawing and perform a save - it leaves me hanging with my Dimensions and Text highlighted and gripped and reports a " invalid AutoCAD command: nil".
    Where is this going wrong. I'm lost
    2009-11
    5,719
    You had many kind things to say - too many for me to comment on individually.
    Suffice it to say, that you're very welcome; I'm happy to help.
    Perhaps you are not going wrong, and I have overlooked something...
    First, lets check the AI_DRAWORDER function to make sure it's loaded. Try this:
    (if ai_draworder
      (prompt "\n** Loaded ** ")
      (prompt "\n** Not loaded ** "))
    What is returned to the command line?
    Computer Specs:
    2009-11
    5,719
    Stop... I've made a terrible mistake.
    Apparently, nested within the AI_DRAWORDER function, is a Command call for the ._DRAWORDER command... which as we're already aware does not play nice with Reactors. *face palm*
    I am sorry to get your hopes up, with regard to the reactor functionality.
    However, all is not lost! You can add a custom LISP command that will accomplish this task like so:
    (defun c:MySave  ( / _Send ss)
      (princ "\rMYSAVE ")
      (vl-load-com)
      (if (not ai_draworder)
        ((lambda (vrsn)
           (load (strcat "acad"
                         (cond
                           ((vl-string-search "16.2" vrsn) "2006")          ; 2006
                           ((vl-string-search "17.0" vrsn) "2007")          ; 2007
                           ((vl-string-search "17.1" vrsn) "2008")          ; 2008
                           ((vl-string-search "17.2" vrsn) "2009")          ; 2009
                           ((vl-string-search "18.0" vrsn) "2010")          ; 2010
                           ((vl-string-search "18.1" vrsn) "2011")          ; 2011
                           ((vl-string-search "18.2" vrsn) "2012"))         ; 2012
                         "doc.lsp")))
          (vlax-product-key)))
        (_Send ss "_f"))
        (_Send ss "_b"))
      (command "._qsave")
      (princ))
    Many, many, apologies for the confusion.
    HTH
    Computer Specs:
    2004-11
    21
    RenderMan, whilst I am disappointing with not being able to automate this functionality through a reactor, I really appreciate your efforts in helping me out.
    Nearly every thread I've ever read on these boards has some contribution from you. So have a my friend - for so consistently helping us noobs out.
    And, by the way - I had no idea bout the ai_commands hidden under the Acad####doc.lsp - thanks for pointing that out.
    Cheers
  1. command reactor selected entity
    By Serhan_BAKIR in forum AutoLISP
    Last Post: 2012-01-13, 01:10 PM
  2. Cancel command with Visual Lisp reactor
    By vasco_rou in forum AutoLISP
    Last Post: 2011-11-24, 01:20 PM
  3. command Reactor and condtional processing
    By rklee in forum AutoLISP
    Last Post: 2009-07-24, 11:42 AM
  4. UnKnown Command Reactor
    By kerbocad in forum VBA/COM Interop
    Last Post: 2009-01-21, 04:45 PM
  5. Embed command reactor inside a drawing.
    By jrd.chapman in forum AutoLISP
    Last Post: 2005-04-25, 04:56 PM
