Hi, Am having trouble with the revit workflow using facebased voids.. Am hoping that I am just missing a setting somewhere to make my problem go away.. Basically the face based void does wierd things to my nested families.. they are the following.
1) Face-based voids no longer cuts the object if the object is a nested family (shared) and then that file is nested or loaded into a project file. For example:
Shared family > nested to another file and cut with face-cased void > this file loaded into project folder (but void is gone)..
2) Face based void removes non-visible families within a nested file.. Example:
Family > nested to another file with 2 of that nested family visible, 2 not visible > this file loaded into project folder. If I cut the object with a face-based void, the "non visible" objects become visible..
Please help.. Would really like to use revit as my workflow, but this roadblock makes it hard for me to quickly adjust my files.. Am I using revit wrong?
thank you!
