Thread: how can i connect wiring from a light switch on a wall to a lighting fixture on the ceiling?
    2011-09
    2
    Default how can i connect wiring from a light switch on a wall to a lighting fixture on the ceiling?
    sorry for this simple question but i cannot seem to connect wiring between the light switch on the wall and the lighting fixture on the ceiling because i can only see them in separate views (plan view and ceiling plan view)?
    cheers
    2007-01
    Suwanee, just north of Atlanta
    160
    Default Re: how can i connect wiring from a light switch on a wall to a lighting fixture on the ceiling?
    In the Ceiling View, try changing the Cut Plane (view Properties:View Range) to something like 4'. That should expose the switch.
    2015-11
    Baltimore, MD
    46
    Quote Originally Posted by ypkhoon326959 View Post
    cheers
    Is the problem that you want to see both of these elements in the same view, or that you want to connect a wire between two elements in two separate views?
    2003-04
    Chino, CA
    4,756
    overlay the floor plan and the reflected ceiling plan on a sheet. Activate a view on the sheet and draw in the wire. You will be able to see both the floor plan and ceiling plan. Revit will snap the two views perfectly to each other on the sheet.
    2011-09
    2
    thanks for all your replies! it works now
  1. Light Switch Wiring
    By cyriousn in forum Revit MEP - General
    Last Post: 2011-06-28, 05:55 PM
  2. Sloped Ceiling and Light Fixture
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2008-01-11, 07:12 PM
  3. ACT Ceiling & Light Fixture Issues
    By rookwood in forum Revit - Rendering
    Last Post: 2005-07-16, 01:18 PM
  4. lighting fixture in multi-level ceiling
    By iffans in forum Revit Architecture - General
    Last Post: 2005-03-10, 12:41 AM
