Thread: Dynamic North Arrow
    2006-03
    Midland, MI
    335
    Cool Dynamic North Arrow
    For all those that are looking for a Dynamic North Arrow where the Letters stay at zero and the rotation can be any degree, Please follow the link below to down load said Dynamic Block. Hope this solves a lot of querries. It did mine. Thanks
    http://www.cadforum.cz/catalog_en/block.asp?blk=2035
    I could stop if I wanted to clshade's Avatar
    2009-01
    B5
    465
    Default Re: Dynamic North Arrow
    These are some other blocks that I have culled that keep Attribs in relative rotation when the object is rotated.
    Charles Shade LT 2013
    www.cshadedesign.com
    2009-01
    B5
    465
    The question was asked about creating the Double Lookup Set in the DynBlk Test_2 in the attached above:
    Open the Block Properties Palette, Go to the Parameter Sets tab, Right click the Lookup Set icon, Copy / Paste then Rename (Lookup Set Double; or whatever), Right click this new Parameter set, Properties, Actions (at the bottom), Click the bar, Click the … , Add Action object Lookup, Ok, Ok, drag and drop as needed. This can be done with any Parameter/Action you want.
  1. North Arrow Alined with True North
    By JH75 in forum Revit Structure - Families
    Last Post: 2010-04-01, 05:54 AM
  2. Dynamic North Arrow
    By tra1133 in forum ACA General
    Last Post: 2008-09-29, 02:11 PM
  3. project north and true north arrow symbol
    By Justin Marchiel in forum Revit Architecture - Families
    Last Post: 2006-03-21, 06:49 PM
  4. project north and true north arrow symbol
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-03-21, 12:05 AM
  5. Project north/True north arrow
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2006-02-28, 01:26 AM
Tags for this Thread
