Thread: Halftone Filled Region
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    Default Halftone Filled Region
    How do you set up a filled region to plot halftone?
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
    2003-05
    Colorado Springs, CO
    97
    Default Re: Halftone Filled Region
    Just place the filled region as solid white or black and adjust the color to gray. In order to print just make sure you click the gray scale option on the print options. Hope this helps.
    2004-03
    Colorado
    323
    Thanks Trent,
    I didn't phrase my question properly because I actually want the filled region pattern (crosshatch or ?) to plot at halftone. I did experiment with graytone and will try some more along those lines.
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
    2003-05
    97
    I would then just play with the color options of the diagonal cross hatch. Good luck.
    2004-03
    Colorado
    323
    I must have missed a graytone setting on my plotter, it is plotting correctly now!
    Thanks again.
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
  1. Filled Regions with Model type Patterns in Halftone
    By Brian Carino in forum Revit Architecture - General
    Last Post: 2010-10-05, 05:23 AM
  2. Halftone Masking Region
    By alex.222271 in forum Revit Architecture - General
    Last Post: 2009-06-26, 09:45 PM
  3. Filled region to masking region?
    Last Post: 2007-08-15, 01:56 PM
  4. Filled Region
    By dsw98 in forum Revit Architecture - General
    Last Post: 2007-01-04, 03:16 PM
  5. Cannot see my filled region
    By audrey.coppock in forum Revit Architecture - General
    Last Post: 2006-11-09, 02:19 AM
