Results 1 to 1 of 1
Thread: MEP Lookup Table - What am i doing wrong...
    2015-10
    11
    Default MEP Lookup Table - What am i doing wrong...
    Trying to learn how to use lookup tables. I think I understand the concept but can’t get all the linked settings to come through.
    I am trying to make a generic Tee, all right , maybe not the easiest to start with…. If I remove the formulas linking to the CSV file and just Flex the parameters manually the work fine. When I plug in the formulas linking them to the CSV, only the ones linking to the “Nominal’s” seem to work (D1 & D2). Also, in the 24to24 it places it but the connecters somehow get skewed.
    I have attached the CSV (XLS) and a Project file that has the Tee loaded. If someone can take a look and tell me what I’m missing id appreciate it.
    HJM
  1. Missing Lookup Table
    By teeka19 in forum Revit MEP - Families
    Last Post: 2017-01-06, 03:57 PM
  2. 2014: Inconsistent Units with Lookup Table - What Am I Doing Wrong?
    By DMagillIII in forum Revit MEP - Families
    Last Post: 2013-08-07, 07:14 PM
  3. 2012: Lookup Table Question
    By Dr._House in forum Revit MEP - General
    Last Post: 2013-01-08, 06:01 PM
  4. Help! Lookup Table Possible?
    By mark.mcmullan in forum Revit MEP - Families
    Last Post: 2009-12-02, 05:27 PM
  5. HELP! ! ! W/ Lookup Table
    By TerribleTim in forum Dynamic Blocks - Technical
    Last Post: 2008-09-10, 09:48 PM
