Results 1 to 8 of 8
Thread: Program to switch to the home tab on the ribbon
    2003-11
    450
    Default Program to switch to the home tab on the ribbon
    I was looking for a keyboard shortcut to activate the home ribbon and have not found anything. Has anybody created something like this?
    2003-11
    450
    Default Re: Program to switch to the home tab on the ribbon
    Here's what I have so far:
    Dim ribcontrol As RibbonControl = ComponentManager.Ribbon
    ribcontrol.ActiveTab = "Home"
    But it gives me a "String" error in Visual Studio.
    Sorry I am very new to .Net
    2003-11
    450
    Got it, see below:
    used code from here http://forums.autodesk.com/t5/NET/Ho...ET/m-p/3049040
     <CommandMethod("setHomeTab")> _
        Public Sub setHomeTab()
            Dim activeDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = activeDoc.Database
            Dim ed As Editor = activeDoc.Editor
            Dim i As Integer
            Dim ribcontrol As Autodesk.Windows.RibbonControl
            ribcontrol = Autodesk.Windows.ComponentManager.Ribbon
            Dim cnt As Integer
            cnt = ribcontrol.Tabs.Count
            For i = 0 To ribcontrol.Tabs.Count - 1
                With ribcontrol.Tabs
                    'ed.WriteMessage("Name: " & .Item(i).Name & " ID:" & .Item(i).Id & Environment.NewLine)
                    If .Item(i).Name = "Home - 2D" Then
                        .Item(i).IsActive = True
                    End If
                End With
            Next
        End Sub
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Nice! Just a few queries :
    Why the db variable? It's never used.
    What about if the Home tab is named slightly differently? Say "Home - 3D"?
    2003-11
    450
    It was a cut and paste from the noted website, I should have reviewed it more in detail. I should have removed the db variable, it looks like it is not needed. If you would like the "Home - 3D" tab current just substitute "Home - 2D". I had to hard code "Home - 2D" because I assigned the program to a shortcut key (F1) with in the CUI.
    Turlock, CA
    6,420
    Quote Originally Posted by GreyHippo View Post
    On this line: If .Item(i).Name = "Home - 2D" Then , you could use the Like operator instead of =.
    C:> ED WORKING....
    LinkedIn
    2015-11
    Jo'burg SA
    4,512
    +1
    Or you could have it ask for input and set according to the string "entered". That way you can have a macro call your function with any of the ribbon tab names. No need to duplicate your function several times for other tabs.
    Or even more "usable" would be to turn it into a Lisp-callable function, taking an argument as the Tab name.
    What I'd do though is generate an inspection function returning a list of tab names. And/or even one which returns the currently active tab. But that's probably a bit too much ... just trying to think ahead.
    2009-08
    93
    If you want the Home Tab I think they all start with "Home" and if so this could work
                        If .Item(i).Name.StartsWith("Home") Then
                        End If
  1. Way to switch back to Home tab?
    By kristy in forum AutoCAD General
    Last Post: 2016-08-16, 05:01 PM
  2. 2014: What happened to ACA Home ribbon? Migrate Issue?
    By bjm in forum ACA General
    Last Post: 2013-07-09, 04:02 PM
  3. 2012: Contextual ribbon tab not switch
    By nguyentruongphat113230390 in forum AutoCAD Customization
    Last Post: 2012-05-03, 08:28 AM
  4. Is there a shortcut to display the home tab in the ribbon?
    By GreyHippo in forum AutoCAD Customization
    Last Post: 2011-10-06, 06:35 PM
  5. Home Tab in Ribbon is Missing
    By cdsuggs in forum Revit MEP - General
    Last Post: 2010-06-30, 06:23 PM
