Results 1 to 6 of 6
Thread: Autodesk Revit Architecture 2012 Update 2 is now available
    Revit Product Manager
    2003-05
    64
    Default Autodesk Revit Architecture 2012 Update 2 is now available
    All,
    I am pleased to announce the release of Web Update 2 for Autodesk Revit Architecture 2012, which is available via Live Update in the product or on Autodesk.com at http://www.autodesk.com/revitarchitecture-download
    The update can be applied to all languages of Autodesk Revit Architecture 2012. We are still in the process of updating the various download pages for each language, but you can download the update from the English page in the meantime.
    A list of the enhancements can be found on the download page.
    http://images.autodesk.com/adsk/file...C_2012_UR2.pdf
    Regards,
    Scott Latch
    Product Manager,
    Revit Architecture
    http://twitter.com/RevitArch
    2003-05
    50
    Default Re: Autodesk Revit Architecture 2012 Update 2 is now available
    should be a sticky, no?
    I could stop if I wanted to Duncan Lithgow's Avatar
    2006-09
    Denmark
    218
    There is now also a hotfix, seems to have stabilised our Revit very well. It's described like this:
    Hotfix – Autodesk Revit 2012 – Improves stability when working with large datasets (64-bit only)
    This hotfix improves product stability when working with large datasets.
    Make sure that Update Release 2 has been applied prior to adding the hotfix. Verify that the build number of Revit 2012 is 20110916_2132.
    NOTE: This hotfix applies to the 64-Bit release of Autodesk Revit 2012 only.
    http://usa.autodesk.com/adsk/servlet...linkID=9273944
    I also just found this hotfix: "Hotfix – Autodesk Revit 2012 – Error with linked model visibility with custom settings": http://usa.autodesk.com/adsk/servlet...linkID=9273944
    2013-01
    6
    I am a college student. With my student account I downloaded Revit Architecture 2012 for my class. How would the updates apply to me if at all?
    2006-09
    Denmark
    218
    I think you'll find that the student version you have is specific to you. As for updates, have you tried installing any?
    Duncan Lithgow
    Revit Support and 'agent of change'
    From New Zealand, in Denmark
    2004-06
    Memphis TN area
    6,700
    2014 was just released, methinks this thread should be updated no?
    AERC, PLLC
    Hernando, Mississippi
  1. Autodesk Revit Architecture 2012 Update 2 Available
    By Dean Camlin in forum Revit Architecture - General
    Last Post: 2011-10-05, 07:04 PM
  2. Autodesk Revit MEP 2012 Update 2 is now available
    By dave.pothier in forum Revit MEP - General
    Last Post: 2011-10-04, 08:34 PM
  3. Autodesk Revit Architecture 2012 Update question
    By DaveP in forum Revit Architecture - General
    Last Post: 2011-07-12, 06:03 PM
  4. Autodesk Revit Architecture 2012 Update 1 is now available
    By scott.latch in forum Revit Architecture - General
    Last Post: 2011-06-28, 09:20 PM
  5. Autodesk Revit Architecture 2012 is now available
    Last Post: 2011-04-11, 07:12 PM
