Thread: Commandline Appload?
    100 Club jonathanschade's Avatar
    2002-05
    123
    Question Commandline Appload?
    I am stumped. I have inherited a group of Tool Pallets a couple are broken. Here is what a typically broke tool looks like:
    ^c^c_-Layer;s;E-Text;;_appload “Y/2012/Support Files/Lisp/qb.lsp”;qb
    As near as I can figure it is breaking at “_appload” This should bring up the commandline Appload but it seems to have been removed from 2012. I have tried to input this manually and I get the same break.
    What am I missing? Has Autodesk provided another way for scripting – running commands at the Command Line?
    I could really use some help.
    Thanks in advance.
    Jonathan R. Schade
    CADD Manager
    Seattle, WA
    100 Club hofcad's Avatar
    2005-09
    111
    Default Re: Commandline Appload?
    If your path is Y\2012\Support Files\Lisp\qb.lsp
    Try:
    ^c^c_-Layer;s;E-Text;;(load “Y/2012/Support Files/Lisp/qb.lsp”);qb
    If your path is Y:\2012\Support Files\Lisp\qb.lsp
    Try:
    ^c^c_-Layer;s;E-Text;;(load “Y:/2012/Support Files/Lisp/qb.lsp”);qb
    Regards HofCAD CSI
    2002-05
    123
    Thumbs up Re: Commandline Appload?
    Thanks for the help. It works well.
    Jonathan R. Schade
    CADD Manager
    Seattle, WA
  1. Stupid Question (I think). ADEQUERY on commandline?
    By Maastricht in forum AutoCAD Map 3D - General
    Last Post: 2010-03-12, 11:32 AM
  2. editing a block attribute through commandline only.
    By nis.194227 in forum AutoCAD Customization
    Last Post: 2008-11-17, 01:56 PM
  3. 2006 crosshair commandline
    By jsnow in forum AutoCAD General
    Last Post: 2008-11-06, 08:59 PM
  4. APPLOAD
    By ifaller in forum AutoLISP
    Last Post: 2008-06-07, 08:45 PM
  5. Opening Drawing files from commandline...
    By Chris Matira in forum AutoCAD General
    Last Post: 2005-12-07, 07:22 AM
