Summary: I wish to be able to create negative dimension values in the family editor.
Description: I create a lot of MEP families which often have connectors attached to small extrusions. Typically the connector is centered on a face of the larger extruion that is the body of the object, but sometimes it will need to be moved to the left or to the right, or upwards or downwards, on an instance basis. Offsetting to the right or upwards (in the postive direction) is no problem, but there is no way to move the extrusion to the left or down (in the negative direction) relative to a reference plane that is stationary, if the default location of the connector is at the center of the body of the object.
Product & Feature: Revit MEP
Submitted: Mon, 10 Oct 2011
