I am trying to export (3) Revit 2011 models to DWG to meet client standards. The DWGs need to be per client CAD standards. I have created an export table to get the layers/colors required. I have nailed down the Architectural translation pretty good, but the MEP and structural are giving me problems with the linked Architectural models. When I export the MEP model with a linked Arch model, the unlinked items come out OK, but the Architectural model gets made into a block and set to layer 0 with incorrect colors. When I explde the Arch background in AutoCAD, most (if not all the objects from the arch model gets put on on override color that I did not assign. When I put all the Arch objects to color ByLayer, the ByLayer color is 242. When I refer back to the Export table, the only line that is assigned color 242 is UNDERLAY. Is this one line all I have to control the linked model's colors and layers? Any ideas how to get the linked model's layers and colors as they are assigned in the export table? I currently have a script that I run with script pro on the exported DWGs to do some cleaning up, so if it requires exploding all the blocks or somethign to that extent, I would be OK with it.
Thank you!
