Thread: Problems with OSNAP: Intersection ACAD 2012
    2006-03
    Kirkland, WA
    8
    Default Problems with OSNAP: Intersection ACAD 2012
    We ran into a mysterious problem where we are unable to snap to an intersection even though the two lines intersect....both are on the same Z plane. The only difference/oddity I've noticed is that when listed, one of the lines is noted with a current UCS & a 3D length for one of the lines:
    LINE Layer: "A-FLOR-LEVL-N"
    Space: Model space
    Handle = 1f6ca6
    from point, X=148'-6 5/16" Y=443'-8 1/4" Z= 0'-0"
    to point, X=164'-8 1/16" Y=443'-8 1/4" Z= 0'-0"
    Length =16'-1 3/4", Angle in XY Plane = 0.00
    Delta X =16'-1 3/4", Delta Y = 0'-0", Delta Z = 0'-0"
    LINE Layer: "A-FLOR-OVHD-N"
    Space: Model space
    Handle = 1c5075
    from point, X=157'-1 9/16" Y=418'-11 1/16" Z= 0'-0"
    to point, X=157'-1 9/16" Y=460'-2 1/16" Z= 0'-0"
    In Current UCS, Length = 41'-3", Angle in XY Plane = 90.00
    3D Length = 41'-3", Angle from XY Plane = 0.00
    Delta X = 0'-0", Delta Y = 41'-3", Delta Z = 0'-0"
    Our intention is to continue in 2d and I can't seem to find a command that works. I tried flatten, but that's not a command in 2012 (and I think that works for meshes & arcs).
    Please HELP! Thanks!
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: Problems with OSNAP: Intersection ACAD 2012
    It might be that the z is so small as to be displayed as 0. Flatten is an express tool, you need to have those installed to use them, they're not part of the default install. Otherwise there's several other lisps you could search for - doing much the same.
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Alternatively, since flatten is not available, manually select the lines and in the properties palette, make the Start Z and End Z to 0, even if its already displaying 0.000. Then try snapping to intersection, lets see if that works.
  1. Corridor Intersection Curb Return Problems
    By georgeh in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-05-03, 02:34 AM
  2. ASD 2012 osnap
    By jeremyg208906 in forum AutoCAD Structural Detailing
    Last Post: 2011-10-24, 02:15 PM
  3. Intersection Assembly Set - Target Problems
    By kevin.jackman in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-05-06, 03:19 AM
  4. Osnap problems
    By birdcube in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-02, 03:17 PM
  5. Osnap Problems
    By Gigliano70 in forum AutoCAD General
    Last Post: 2008-08-05, 12:13 AM
