Results 1 to 6 of 6
Thread: Import of .sdnf files in Autodesk Structural detailing 2012
    2011-10
    2
    Default Import of .sdnf files in Autodesk Structural detailing 2012
    Hello everybody!
    Does anybody know how to import a .sdnf file in Structural Detailing 2012? I need to work with a steel structure that was created with Autodesk Plant 3D 2012.
    Thank you!
    2008-06
    109
    Default Re: Import of .sdnf files in Autodesk Structural detailing 2012
    There is no way to import *.sdnf file into AutoCAD Structural Detailing 2012.
    2011-10
    2
    OK, thanks for your answer, so from you said i deduct that it's not possible to import an steel structure to ASDetailing from Plant3D?
    Thank your very much,
    David
    2010-04
    110
    The way I see is:
    Create the structure you need in ACAD plant.
    Create the suporting structure in ASD
    Overlap them in Naviswork.
    2007-04
    9
    Hi,
    You can import an SDNF file into Revit Structure using the extensions ribbon and then link the Revit Steel frame to ASD.
    I would say that your best bet is to download the object enabler for Plant 3D and then create the steelwork directly in ASD
    2012-02
    Quote Originally Posted by Tomasz.Fudala View Post
    Unitec developed an intelligent SDNF Import Interface for AutoCAD PLANT 3D
    and for Mechanical systems like Inventor. Additional for ASD there will be an
    Interface soon available too. Based on geometry we provide a multi-CAD
    SDNF Export interface e.g. AutoCAD. May be this give some ideas
  1. Structural Detailing 2012 and RC
    By DaleSmith in forum Revit Structure - General
    Last Post: 2011-12-02, 10:24 AM
  2. AutoCAD Structural Detailing 2012 Service Pack 2 is now available
    By Tomasz.Fudala in forum AutoCAD Structural Detailing
    Last Post: 2011-09-20, 08:36 AM
  3. AutoCAD Structural Detailing 2012 is now available
    By Dariusz.Kwolek in forum AutoCAD Structural Detailing
    Last Post: 2011-07-28, 12:44 PM
  4. Autodesk Robot Structural Analysis 2012 now available !
    By pawelp in forum Robot Structural Analysis
    Last Post: 2011-07-02, 09:44 PM
  5. Crosshairs in Autocad Structural Detailing 2012
    By acommero in forum AutoCAD Customization
    Last Post: 2011-05-18, 07:01 PM
