Thread: DWF markups appear exploded
    Active Member troy.crandell635379's Avatar
    2007-06
    Phoenix, AZ
    72
    Default DWF markups appear exploded
    Not sure if anyone has seen this before, but upon linking a DWF markup set into Revit I get some markups that appear to be exploded. Literally the leader line pointing to something is in one spot and the text associated with it is in a completely different spot. On another sheet the markup is completely off the sheet. Everthing appears fine in DR, but once linked into Revit no bueno.
    Troy Crandell
    BIM Implementation Specialist
    2009-01
    45
    Default Re: DWF markups appear exploded
    How are you linking the file into Revit? If the CAD file is a very long distance away from the origin, you often end up with crazy graphics on the linked file. Make sure that your CAD File is located close to the origin before linking it in. Hope this helps.
  1. JPG exploded
    By waghorne in forum CAD Management - General
    Last Post: 2009-08-19, 02:51 PM
  2. DWF Markups
    By pdavis in forum Revit - API
    Last Post: 2009-04-27, 04:27 AM
  3. Exploded In CAD!
    By winnwgomez in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-09-17, 01:55 PM
  4. DWF Markups
    By cdchristian in forum Revit Architecture - General
    Last Post: 2007-03-09, 07:59 PM
