Thread: 3-D Section Box Help
    2011-09
    45
    Default 3-D Section Box Help
    Hello all,
    I'm fairly new to revit and i'm trying to use the section box tool in the properties menu to cut the building in pieces and get a better look.
    I'm in a 3-d view and when i check the box that says "section box", nothing happens. On other projects, when i did this, a purple box would surround the building and i could cut the building as i wished. However, for some reason its not having an effect. I've tried duplicating new 3-d views and creating brand new ones but it doesn't do anything. Any ideas? Any help is appreciated, thanks
    Rob
    100 Club dennis howell's Avatar
    2007-01
    Suwanee, just north of Atlanta
    160
    Default Re: 3-D Section Box Help
    The section box has two places to check to turn it on and off: 1) properties of the view, 2) Visibility Graphics/Annotation tab. So, maybe you are turning it on in the view properties, but not the VG.
    No matter how much you adjust your View Range,
    if you have to wear glasses, you will still need to wear glasses.
    100 Club Overconstrained's Avatar
    2005-05
    Hamilton NZL
    158
    The section box is hidden by default now for some reason. If you click the light bulb along the bottom view control bar it will be visible in red as a hidden item.
    Senior Architectural Technician
    Dean Burdett
    SEKTA Architects Ltd.
  1. Replies: 2
    Last Post: 2014-04-13, 07:56 AM
  2. Pipe network structions to show structure section in section views
    By Civil 3D Wishes in forum Civil 3D Wish List
    Last Post: 2010-10-06, 01:04 AM
  3. Drawing Section Lines/Section Line Style
    By Mike Y in forum Inventor - General
    Last Post: 2007-01-12, 08:47 PM
  4. wall section/ building section tags/cuts
    By belyo in forum Revit Architecture - General
    Last Post: 2006-12-13, 07:39 PM
  5. Linking Section Extents to Section Head/Tail
    By narlee in forum Revit Architecture - Wish List
    Last Post: 2005-06-21, 04:30 PM
Tags for this Thread
