Thread: AutoCAD LT 2012 update
    2011-06
    Default AutoCAD LT 2012 update
    I just updated to LT2012 and am having problems with production so to get something done I would go back and launch LT2004 to find that 2012 settings have taken place. Such As I have no shortcut commands I have to spell out every command. it only wants to select a .stb file when plotting, although I set that I want to print with .ctb file I only have the selection of .stb even after I path it to look in the folder with .ctb files. This seems to only be a couple of transitional problems that will be occurring...any help please?
    Cairo - no, not Illinois
    5,069
    Default Re: AutoCAD LT 2012 update
    whether to use stb or ctb for plotting is embedded in the drawing, and typically based on the dwt file used to start the drawing.
    to change from one to the other,type CONVERTPSTYLES at the command line.
    2001-12
    St. Louis
    5,407
    Quote Originally Posted by walkerj548863 View Post
    Hi there, I'm going to move this from the AutoCAD forum to the AutoCAD LT forum!
    Best of luck.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2009-01
    B5
    544
    What are your LT 2012 issues?
    Those need to be solved first so that you do not need to go back to the LT 2004 version.
    And it is likely that you have a bad install of the LT 2012 if it did something to the LT 2004 installation. That should not happen.
  1. 2012: MS update switched r.2012 entity colors?
    By mnielsen in forum Revit Architecture - General
    Last Post: 2013-03-04, 09:52 PM
  2. Update blocks for Autocad 2012
    By mmunoz930478 in forum AutoLISP
    Last Post: 2012-10-08, 11:47 AM
  3. C3D 2012 Update 1 issue
    By civil3Dguide in forum AutoCAD Civil 3D - General
    Last Post: 2011-12-13, 09:06 PM
  4. Autodesk Revit MEP 2012 Update 2 is now available
    By dave.pothier in forum Revit MEP - General
    Last Post: 2011-10-04, 08:34 PM
  5. Revit Structure 2012 Web Update 1 - Hangs
    By Silleke in forum Revit Structure - General
    Last Post: 2011-07-14, 09:15 PM
