Thread: create concrete column with finishes
    2011-10
    Default create concrete column with finishes
    hi,
    i work on revit architectural
    i would like to make a concrete column with finishes (plaster & paint)
    as we know we can create the floor or wall by concrete and finishes
    can we use the same method.
    Vancouver, BC Canada
    3,753
    Default Re: create concrete column with finishes
    Welcome to the forums.
    You can't create 'layers' like you can with wall and floor assemblies but you could edit the column family to include finish layers that have material parameters.
    I would suggest creating separate 'column finish' families that would be placed after columns are placed. This would give you a little more flexibility in terms of mixing and matching finishes, heights of finish, etc. with columns and would allow one discipline to manage columns (structural) and one to manage finishes.
    2005-03
    London UK
    19
    Smile Re: create concrete column with finishes
    In order to do this you really need to create your own column family from a standard column family template. You then want to model a structural and finishes extrusion and create a finishes width parameter to drive the width of this element.
    Then create a finishes material and apply this to the new extrusion.
    I attach a sample showing the type of things as it is quicker that writing this...
    Enjoy...
    Paul
    2016-05
    hi, I have created plaster layer in column, how to avoid the plaster at the intersection of walls with the column., is there a way to join wall plaster and column plaster automatically
  1. Shaped Concrete Column
    By watson.145302 in forum Revit Structure - Families
    Last Post: 2016-02-23, 05:08 AM
  2. steel column on top of concrete column
    By szaky007333406 in forum Robot Structural Analysis
    Last Post: 2011-06-27, 12:12 PM
  3. Material cut from concrete column in elevated column schedule
    By khanson-3b in forum Revit Structure - General
    Last Post: 2011-04-10, 06:24 AM
  4. Concrete Column Schedule
    By ckeelor in forum Revit Structure - General
    Last Post: 2010-11-17, 02:18 AM
  5. Trouble Attaching Steel Column to Concrete Column Below
    By amiller.223744 in forum Revit Structure - General
    Last Post: 2009-09-02, 03:13 PM
