Thread: Cut Roof Edge
    2011-10
    7
    Default Cut Roof Edge
    Hi,
    How i can set a perpendicular cut the roof edge?
    In the properties i can set only a cut plumb or a square cut, in these properties i have changed the values​​, but without result.
    Thanks
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Cut Roof Edge
    Set the roof eve to Two Cut - Square, and then set the fascia depth equal to the roof thickness.
    2004-05
    Auckland, New Zealand
    341
    If you need to do this for the Top Edge/Ridge of the Roof - Use Opening by Face.
    2013-04
    21
    Great answer, thanks!!
  1. Sloped Roof Edge
    By rsotak in forum Revit Structure - General
    Last Post: 2011-05-19, 01:10 PM
  2. Roof Edge
    By jcoe in forum Revit Architecture - General
    Last Post: 2009-11-19, 02:38 PM
  3. Roof Edge Question
    By wse1 in forum Revit Architecture - General
    Last Post: 2008-08-29, 12:46 PM
  4. Roof Bearing edge
    By ryan.87191 in forum Revit Architecture - General
    Last Post: 2007-04-10, 09:19 PM
  5. Rectangular Roof Edge
    By sifuentes in forum Revit Architecture - General
    Last Post: 2006-06-08, 10:30 PM
