Is there a setting some where that will stop the FDO connect from executing a query every time I move my mouse. I have 8 images and just panning, it executes.
Will Image Import convert the coordinate system like FDO? If so, How?
I was trying to find the solution to it - without any success unfortunately. If you will be able to sort it out, please post a solution.
Importing images will help.
You could also group them in display manager and turn them off when not needed.
Will Image Import convert the coordinate system like FDO? If so, How?[/QUOTE]
I'm not sure if it converts it. But you could try bringing them to map with correct coordinates and maybe try to attach the drawing with images as source drawing and than query data into drawing with the coords that you need?
