Results 1 to 10 of 11
Thread: Masking Region not masking properly -- View not set to wireframe
    2001-02
    Allentown, PA
    207
    Default Masking Region not masking properly -- View not set to wireframe
    I have a user who's masking regions are not behaving properly, they are not masking like they should. The view is not set to wire frame.
    Any ideas?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Masking Region not masking properly -- View not set to wireframe
    Are the masking regions set to transparent? If you create a brand new one does it do that?
    Scott D. Brown, AIA
    BECK
    2001-02
    Allentown, PA
    207
    Quote Originally Posted by sbrown View Post
    Transparent? You can only make filled regions transparent, unless I am totally missing a setting...?
    It is only for one plan view, in all other views they masking regions work perfectly. Also filled regions in this one plan view even when set to Opaque are not behaving properly either.
    Last edited by Joshua Kohl; 2011-10-27 at 02:28 PM. Reason: didn't finish original post before hitting submit
    2004-06
    Memphis TN area
    7,048
    As far as I know there is no way to set a masking region to be transparent, other than having the view in wireframe. Masking regions do not have any type properties, or any instance properties other than Area and Comments. There is no Masking Region subcategory for Detail Items in V/G that can be set to transparent.
    Only other thing I can think of is a view range issue. Not sure about floor plans but I have seen ceiling plans act like wireframe views even when set to Hidden Line if the view range is set to Unlimited across the board.
    2001-02
    Allentown, PA
    207
    I had the user check and the view range for that plan is associated with that level and the offsets are at 0'-0".
    2001-02
    Allentown, PA
    207
    The problem has been figured out.
    In the View Graphics dialog box, on the Model Categories tab the "Detail Items" line had "Transparent" checked. Sometimes it's the mundane things that get overlooked.
    2009-06
    St. Louis, Missouri
    162
    That's what Scott was referring to when he asked if they were set to transparent. He just neglected to mention "in the visibility/graphics overrides."
    2003-05
    Coast to Coast
    4,440
    And you all thought I didn't know what I was talking about
    Scott D. Brown, AIA
    BECK
    2001-02
    Allentown, PA
    207
    Red face Re: Masking Region not masking properly -- View not set to wireframe
    My apologies.
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by rosskirby View Post
    Scott said masking regions specifically, which you cannot make transparent on their own. The OP said the user had the entire Detail Items category set to transparent, which was the culprit.
  1. 2013: Masking region not masking: wireframe is not on
    By graphite in forum Revit Architecture - General
    Last Post: 2012-09-14, 03:28 PM
  2. Masking region
    By tonyv in forum Revit - Platform
    Last Post: 2010-01-07, 11:27 PM
  3. Field Region turns into Masking Region
    By thalim in forum Revit Architecture - General
    Last Post: 2009-11-13, 06:40 AM
  4. Masking Region
    By kkintz in forum Revit Architecture - General
    Last Post: 2009-10-20, 03:33 PM
  5. Break Line not masking properly
    By etornberg in forum Revit Architecture - General
    Last Post: 2007-04-30, 05:11 PM
