Results 1 to 6 of 6
Thread: Fence - LISP to pick a pre determined fence line?
    2005-01
    20
    Default Fence - LISP to pick a pre determined fence line?
    I use the "fence" command often inside other commands. I have the need to select a pre-determined line as my "fence" line. Anyone know of a lisp routine (or another way) that I can choose a pre-determined line as my fence line?
    THANKS!
    0,0,0 The Origin
    8,024
    Default Re: Fence - LISP to pick a pre determined fence line?
    During which commands?
    A line isn't a fence in autocad terminology but you could use a line to provide two pick points.
    Some more info might help.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-01
    20
    I am using it within the "change to current layer" command.
    I am using after I export my Civil 3D surface to 3D faces and before importing it to Navisworks, I need to put the individual faces on their own layers (something Civil 3d can't do yet).
    SO it is very time consuming, as I have to update the Navisworks model often. If I could draw a polyline around the areas I want to change (say a road) and re-use this polyline as the fence line everytime I need to do it I would save a lot of time.
    0,0,0 The Origin
    8,024
    In acad terms a fence crosses the objects to be selected.
    To select with an enclosure you would use BOX, Crossing, Window or one of the Polygon options - which doesn't answer the question, I know.
    If you DO have a single line passing through the faces you want to change, the Fast Select express tool (alias = FS) will pick everything that touches the line and LAYCUR will immediately change all of them.
    It shouldn't be difficult to combine them into a macro or a lisp.
    I hope that helps but I'm not sure that it does but at least it only requires a single pick to select the line.
    John B
    2005-01
    20
    AWESOME!!
    Fast select! Never heard of it! Just what I was looking for. When was that one added? No-one in my office had heard of it... very useful!
    Thanks!
    0,0,0 The Origin
    8,024
    I'm glad it helped - I learned a bit bit too whilst researching.
    John B
  1. Fence?
    By wbenatti in forum Português - Revit
    Last Post: 2009-02-10, 10:00 AM
  2. FENCE ??
    By shaunamorain in forum Revit Architecture - General
    Last Post: 2007-01-12, 03:54 PM
  3. Fence line style
    Last Post: 2006-08-05, 10:27 AM
  4. Chainlink fence
    By gtobias in forum Revit Architecture - Families
    Last Post: 2004-11-23, 12:45 AM
  5. Line Pattern Fence
    By David Kim in forum Revit Architecture - General
    Last Post: 2003-10-20, 07:50 PM
