Results 1 to 1 of 1
Thread: MLINES
    2008-02
    North Liberty
    34
    Default MLINES
    Just a simple question. I created an Mline with a 0.333" scale. When I draw a line between the top and bottom lines I see my desired length as being 0.33" Great. When I go into MTSTYLES for this saved style the window is telling me the offset is 0.5 and -0.5. How can this be? I go back into my drawing redraw a line using this style and it measures 0.333" If the offset is from the center, how can the offset be +/-.5 instead of +/-.1667?
    Figure it out. It was all about the scale setting affecting the offset.
    "Whatever you are, be a good one."
    — Abraham Lincoln
  1. Dimensioning Mlines in paperspace...
    By steve922542 in forum AutoCAD General
    Last Post: 2007-10-04, 10:57 PM
  2. MLINES com LWEIGHTS das linhas e BUG
    By adrisoares in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2007-03-19, 09:53 AM
