Thread: Curb & Gutter Profiles
    2011-11
    2
    Default Curb & Gutter Profiles
    Hi there ;
    I would like to know how can I generate in the same profile view of the center line , my left and right line of the C&G ( Note : the road has been superlevated )
    Greatly appreciate all the help
    2011-11
    British Columbia, Canada
    7
    Default Re: Curb & Gutter Profiles
    I don't use ribbons but under the profile pull-down there are two options to achieve this;
    1) If your gutterline is constructed using the super elevation tool in the corridor properties, there is an option to superimpose profile from corridor featureline. Then select flowline or gutter to do so. (Or you may have to create a 3d featureline from corridor).
    - In the corridor properties there is a superimpose featureline option.
    2) If you did your gutterline grade via a secondary alignment/profile then in the profile pulldown sellect superimpose profile then select source & destination.
    I'm not an expert but give it a try.
    2011-11
    2
    Hi
    Thank you. I will give a try and see how it goes .
    2001-10
    Arizona
    2,337
    You may also be interested in a link I have posted outlining a process; the results of which are probably going to be more to you liking.
    http://forums.augi.com/showthread.ph...wpost&t=135395
  1. Curb & Gutter Assembly on Parking Lot Feature Lines?
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2011-08-17, 11:55 PM
  2. Sloping curb & gutter
    By PaperStreet SoapCO in forum Revit Architecture - General
    Last Post: 2010-02-11, 05:20 PM
  3. Dynamically linked Curb Profiles
    By jason.williams in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-03-04, 10:06 PM
  4. Steel Gutter Profiles
    By beegee in forum Revit Architecture - Families
    Last Post: 2005-06-30, 03:06 PM
