Results 1 to 8 of 8
Thread: Annotative Grid Bubbles?
    I could stop if I wanted to nextvkin's Avatar
    2007-07
    315
    Default Annotative Grid Bubbles?
    Hi,
    Late bloomer here, just starting to look at things annotative (dimensions, texts), and was wondering if grid bubbles can be annotative as well. I've been using layers for this, as I have with dims & texts, and decided to come into the 21st C at last. Thanks.
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Default Re: Annotative Grid Bubbles?
    aca handles the insertion scale of grid bubbles. Since they are blocks, they can't really be annotative like text or mtext.
    C:> ED WORKING....
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,845
    Sure can. Grid bubbles are Multi-View Blocks in ACA. If you make the AutoCAD block you assing as the view block to the Multi-View Block for your grid bubble annotative, then the Multi-View Block will be annotative as well.
    The default grid bubble Multi-View Block is called StandardGridBubble. It gets generated on the fly if it is not present in your drawing, but you can customize the default to match your firm's standards by creating a Multi-View Block Definition of that name and putting it in your template file(s).
    David Koch
    2007-07
    315
    My question was originally posted to the vanilla AutoCAD forum because I was hopeful that it was possible there. I knew it was possible here & that other BIM program. However, thanks for elaborating on this here, David.
    2003-03
    1,845
    In vanilla AutoCAD, the bubble would be blocks and you could make the block annotative. Now if you are using them thar newfangled dynamic blocks, then you would need to get an answer from someone who knows how to use them. Dynamic blocks generally do not play nicely with ACA content, so I have never taken the time to attempt to master them.
    David Koch
    2007-07
    315
    David,
    Interesting what you said about dynamic blocks not playing nicely with ACA, cause I was going to use some of mine in plan view, like parking spaces, & other repetitive 2d objects. I'll still give it a go & see what happens. Thanks.
    2003-03
    1,845
    You can use Dynamic Blocks in an ACA file, and, so far as I know, they will work just fine. They will not interact with the Display System, however (just like regular AutoCAD blocks or other regular AutoCAD objects do not).
    Where they will not work is as a view block in a Multi-View Block definition (they may "work", but they will not be dynamic), or as a custom display block in an ACA style.
    David Koch
    2007-07
    315
    David,
    Thanks for the feedback, there are obviously the subtleties of the program I have yet to discover, but at least it'll prepare me for what to expect.
  1. Grid Bubbles
    By michael91077 in forum Revit - Platform
    Last Post: 2008-09-10, 04:59 PM
  2. Hide Grid Bubbles, but not Grid Lines
    By brethomp in forum Revit Architecture - General
    Last Post: 2007-05-08, 07:46 PM
  3. Need generic grid bubbles & section bubbles
    By paullee in forum Revit Structure - General
    Last Post: 2006-09-19, 08:03 PM
  4. grid bubbles and level bubbles
    By sopori in forum Revit Architecture - General
    Last Post: 2004-08-25, 11:33 PM
