Results 1 to 7 of 7
Thread: Compatibility
    2004-06
    Slidell, Louisiana
    972
    Default Compatibility
    Which hardware manufacturer has the best compatibility with AutoCAD 2005 and has anyone had any problems with the XEON processor w/Autocad 2005?
    2004-07
    Detroit Michigan
    2,508
    Default Re: Compatibility
    Are you getting a system????
    I have a xeon machine and a copy 2005 coming to me when IT gets around
    to setting me up.
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    564
    Quote Originally Posted by rmk
    Using dual Xeon sytems here on 3 stations and Single Xeons on 3 others.... No problems at all with 2005.
    2004-06
    Slidell, Louisiana
    972
    I am running a Dell Precision 450 w/512MB ram, 3.0 gz XEON. I get
    (not responding) errors frequently. The machine seems to be really slow
    for the hardware compared to other machines I've used. Any suggestions?
    2015-12
    Texas
    564
    We are using IBM IntelliStations and have had no issues that I know of in the last 3 years with any programs.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    My Dell Precision 650 w/ 1024MB ram is a workhorse machine. It's crashed only twice in two years running Windows 2000. (Both times a software issue, not hardware). It never slows down.
    It sounds like you have a software issue. If you get that message with a particular program you might try to re-install it (usually this helps). If it happens on a variety of programs then a fresh Windows install may help things.
    But before doing this, make sure you don't have too many applications running at the same time. Perhaps you may wish to run programs like ad-aware or spybot search and destroy on it to make sure you don't have any spyware slowing your system down.
    Between running these programs and re-installing your software (if need be) you should have a clean/fast system and it will be worth the time you took to do it.
    Click here for Spybot
    Click here for Ad-Aware
    2004-06
    Slidell, Louisiana
    972
    THANKS BMYERS. IT SOUNDS LIKE THAT MIGHT BE MY PROBLEM. I GET NOT RESPONDING ERRORS IN AUTOCAD AND MOST ALL MICROSOFT PROGRAMS BOTH RUNNING ALONE AND MULTIPLE PROGRAMS. IS A FRESH INSTALL SOMETHING A NOVICE CAN DO OR DO I NEED A COMPUTER TECH?
  1. Compatibility
    By phil.210189 in forum AutoCAD LT - General
    Last Post: 2012-05-14, 02:54 AM
  2. Backwards Compatibility - PLEASE
    By bpoppe in forum Revit Architecture - Wish List
    Last Post: 2011-05-03, 11:10 AM
  3. Compatibility Issues
    By kyler in forum ACA General
    Last Post: 2008-09-02, 05:03 PM
