Thread: Looking to get the BURST command in LT
    2007-02
    29
    Question Looking to get the BURST command in LT
    I just started work at a company that is using LT 2012. They are using some problematic block with embedded attributes that need to be bursted and edited.
    We all know what happens if I XPlode these blocks.. no fun!
    Anybody got a burst command working for LT?
    I'm not likely to get a product like this http://www.ltexpress.com/ used at my company, so even if that contains BURST, it's not really an option.
    0,0,0 The Origin
    8,569
    Default Re: Looking to get the BURST command in LT
    I'm guessing that you know that you can't run LISP with LT.
    Google "diesel programming" - I expect that there will be at least one routine out there.
    Edit - sorry, forget that.
    There was an excellent on-line source of DIESEL routines but I cannot find it now.
    John B
    I could stop if I wanted to pendean's Avatar
    2001-12
    Dallas, TX
    215
    There is no such option: DIESEL is a basic macro laguage that totally relies on core commands in LT. It is not some form of magic hidden Lisp.
    If there was a core command to emulate BURST the OP would not be here looking for that Express Tool.
    OP: if you want BURST, find a colleague or friend with full AutoCAD with Express Tools installed to do it for you. Or post the file here with detailed instructions and maybe someone can help.
    Dean Saadallah
    AutoCAD and LT User
    BLOG|TW|FB|PIN
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Can you not edit these through the BE?
    This will affect all but you can run ATTSYNC on the several if need be afterwards.
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
  1. 2014: BURST command Error
    By darrellwinfrey589074 in forum AutoCAD General
    Last Post: 2014-03-25, 02:56 PM
  2. Convert Explode command to Burst command?
    By stusic in forum AutoLISP
    Last Post: 2013-06-18, 11:55 PM
  3. 2011: HIGHLIGHT reverts to 0 after burst command?
    By stimmo520 in forum AutoCAD General
    Last Post: 2011-05-09, 01:07 PM
  4. Using the Burst command with LISP ?
    By stephen.coff in forum AutoLISP
    Last Post: 2011-02-08, 04:20 PM
  5. Modified Burst Command
    By thomas-p in forum AutoLISP
    Last Post: 2006-03-17, 02:51 PM
Tags for this Thread
