Thread: Looking to get the BURST command in LT
    2007-02
    29
    Question Looking to get the BURST command in LT
    I just started work at a company that is using LT 2012. They are using some problematic block with embedded attributes that need to be bursted and edited.
    We all know what happens if I XPlode these blocks.. no fun!
    Anybody got a burst command working for LT?
    I'm not likely to get a product like this http://www.ltexpress.com/ used at my company, so even if that contains BURST, it's not really an option.
    0,0,0 The Origin
    8,570
    Default Re: Looking to get the BURST command in LT
    I'm guessing that you know that you can't run LISP with LT.
    Google "diesel programming" - I expect that there will be at least one routine out there.
    Edit - sorry, forget that.
    There was an excellent on-line source of DIESEL routines but I cannot find it now.
    2001-12
    Dallas, TX
    229
    There is no such option: DIESEL is a basic macro laguage that totally relies on core commands in LT. It is not some form of magic hidden Lisp.
    If there was a core command to emulate BURST the OP would not be here looking for that Express Tool.
    OP: if you want BURST, find a colleague or friend with full AutoCAD with Express Tools installed to do it for you. Or post the file here with detailed instructions and maybe someone can help.
    2009-01
    B5
    544
    Can you not edit these through the BE?
    This will affect all but you can run ATTSYNC on the several if need be afterwards.
  1. 2014: BURST command Error
    By darrellwinfrey589074 in forum AutoCAD General
    Last Post: 2014-03-25, 02:56 PM
  2. Convert Explode command to Burst command?
    By stusic in forum AutoLISP
    Last Post: 2013-06-18, 11:55 PM
  3. 2011: HIGHLIGHT reverts to 0 after burst command?
    By stimmo520 in forum AutoCAD General
    Last Post: 2011-05-09, 01:07 PM
  4. Using the Burst command with LISP ?
    By stephen.coff in forum AutoLISP
    Last Post: 2011-02-08, 04:20 PM
  5. Modified Burst Command
    By thomas-p in forum AutoLISP
    Last Post: 2006-03-17, 02:51 PM
