Thread: 120V, 3 Pole, Multi Branch Circuit
    2009-06
    Orlando
    64
    Default 120V, 3 Pole, Multi Branch Circuit
    Hello,
    This question requires a little bit of electrical distribution knowledge in order to make sense of it, but here it goes!
    I'm trying to make a "Multi Branch Circuit" that has three 120V circuits with a Shared neutral. Per NEC 210.4(B), the three circuits need to be simultaneously disconnected at the point where the branch circuit originates; meaning at the panel board circuit breakers.
    To accomplish this, I want to make a 3-pole circuit; which would result in a 3 pole breaker shown on the Revit panel board schedule. The problem with this is that Revit will not let you create a 120V, 3 pole circuit because it thinks that I'm making a three phase circuit which has a voltage of 240V or 208V.
    Has any other electrical engineer come across this problem or even thought about this before? I've drafted something to attempt to describe in pictures what I'm trying to do, please see the attachment.
    Thanks for any input,
    Simon
    2011-08
    3
    Default Re: 120V, 3 Pole, Multi Branch Circuit
    After you have created the separate circuit for each item. Drop in a Junction box with 0 load and do not circuit it to any panel. In a working view draw a wire from teh junction box back to the individual circuits that wire will show a single neutral hot and ground on the tick marks. From the Junction box draw a home run and label it. The label should show 3 circuits and the homerun will show a single neutral with 3 hots and a ground.
    The panel should read the individual circuits.
    2009-06
    Orlando
    64
    William,
    Thank you for your response. I can see how your approach would allow me to show the three circuits on the homerun tag; however this circuit breakers would still show as single pole breakers on the panel schedule.
    2011-08
    3
    Then try a similar approach connect the receptacles by wires to the junction box with the appropriate load on each receptacles, do connect them directly to the panel. The junction box should have 0 load but set up to be as a 208 V /3 pole connection and power that directly to the panel.
  1. Branch Circuit vs Feeder Circuit for Voltage Drop
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-12-01, 02:31 PM
  2. 2013: Tagging homerun for multiple pole circuit......
    By shannonstandish in forum Revit MEP - General
    Last Post: 2013-10-22, 06:09 PM
  3. 2012: Changing multi-pole circuit settings in middle of project
    By kevin.campbell408390 in forum AMEP General
    Last Post: 2013-10-22, 03:31 PM
  4. Electrical Branch Circuit Arrows - Movable Location
    By Mitch Mermel in forum Revit MEP - Wish List
    Last Post: 2011-08-27, 02:08 PM
  5. Panel Schedule Branch CIrcuit Issues
    By revans.89349 in forum AMEP General
    Last Post: 2009-11-25, 09:05 PM
