Thread: assigning materials to family parameter
    AUGI Addict MikeJarosz's Avatar
    2003-09
    New York NY
    1,005
    Default assigning materials to family parameter
    I'm not new to Revit, but I am new to Revit rendering. I've done lots of model building and CDs in Revit, but not a lot of full-out rendering. I created a simple extrusion to be a granite countertop, using a material parameter in the RFA file, then loaded it into the project. I assigned it to be a white stone with some speckles.
    I have decided I want to reverse the color and make it black granite. I used edit type. I have not made any custom materials defs, everything I needed was already inside Revit (2011). I linked graphic appearance to render appearance.
    The countertops in my plan refuse to change from the original white to the new black. When I go back to the family and edit type, the black granite reappears in the parameters form. I have loaded it into the project after every edit.
    It's stuck on the original setting and won't budge.
    Any ideas on what I'm doing wrong?
    "everything you know is wrong...." -FST
    I could stop if I wanted to Revitaoist's Avatar
    2009-11
    277
    Default Re: assigning materials to family parameter
    assign the material parameter in the family as "counter top"
    control the render appearance of material "counter top" in the project
    any changes in material should be done to material "counter top" in the project, not anything in the family.
    ICC Building Plans Examiner
    CABEC Energy Plans Examiner
    Licensed Building Contractor
    Architectural Drafter
  1. Assigning materials on an imported family object
    By nso in forum Revit Architecture - General
    Last Post: 2011-02-15, 05:47 PM
  2. Revit TotD – 7.23.09: Family Materials, Parameter Application
    By rkitect in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-07-23, 01:47 PM
  3. Revit TotD – 7.21.09: Assigning Family Materials, the Direct Approach
    Last Post: 2009-07-21, 03:32 PM
  4. Assigning Materials
    By gio_2 in forum AMEP General
    Last Post: 2009-01-13, 07:30 PM
  5. Materials Parameter Type in the Family Editor
    By narlee in forum Revit Architecture - General
    Last Post: 2003-12-19, 03:47 PM
