Thread: civil 3d side data
    2010-08
    6
    Question civil 3d side data
    Can anyone give me a direction on how to do side data in C3D. I have attached a sample pdf to direct specifically to show what i am looking.
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Default Re: civil 3d side data
    BUMP...
    other than manual placing offset labels from an alignment and then lining them up... I also would like to see a better way!
    :Cheers:
    2015-12
    Central Oregon
    591
    If you were to consider 3rd party software, SincpacC3D has the command TOPOSTATIONLABELER which can help automate this. As of this post, the help file for this command is missing the images so I will post them here:
    2015-12
    Arizona
    2,478
    Here is a crazy idea...
    One would create an 'alignment' that would have a vertex for each side item.
    One would create a Label for Alignment Geometry Point(s)
    The Label would include a piece of Reference text (Cogo Point)
    formated to show staton offset, and the point desscription
    This would probably be a real pain to use...however you would get a constant placement from the centerline
    There might even be a way to do this using an XDREF
