Revit Flexible Piping / System Inspector
Summary: That MEP Flexible pipe worked the same as rigid piping as far as system inspector operates.
Description: When using system inspector the flows get confused at all flexible piping locations and the system inspector gives wrong flow directions. If you have more than 1 flexible pipe on a system. It does not calculate at all after the first flexible piping. Then when a person runs the pipe loss calculation, the critical path is wrong. The only way to fix it is connect the piping rigidly, do the calculation, then switch back to flexible pipe. This is a work around the issue, but it would make sense that flexible piping would work the same as rigid piping.
Product and Feature: Revit MEP - MEP Pipe Sizing - (Mechanical
Submitted By: christian.dostert992313 on 07/24/2019
- You may not post replies
- You may not edit your posts
Forum Rules
