Thread: Make joist extended ends visible on coarse view.
    Wish List Administration
    2011-08
    4,592
    0 Did you find this post helpful? Yes
    Default Make joist extended ends visible on coarse view.
    Summary: Make joist extended ends visible on coarse view.
    Description: When a joist is added in plan and has a joist extended end it does not show the end in coarse view. If you switch to fine view it shows, but I don’t print in fine view. The only “work around” that I have is by adding a line to the end of the joist, but when you change the spacing all your lines are then off.
    Product & Feature: Revit Structure
    Submitted: Wed, 16 Nov 2011
    2010-06
    Canada
    3
    Default Re: Make joist extended ends visible on coarse view.
    This can be fixed inside the families using a conditional formula and symbolic lines.
  1. Make joist extended ends visible on coarse view.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-07-16, 07:52 PM
  2. how do you make first floor visible on basement view
    By jwenzeljr in forum Revit Architecture - General
    Last Post: 2010-06-22, 07:21 PM
  3. Make Grid lines visible in a certain view?!
    By samov in forum Revit Architecture - General
    Last Post: 2008-06-05, 08:53 AM
  4. Making extended ends on bar joists
    By terwin in forum ACA General
    Last Post: 2006-08-10, 04:31 PM
  5. Unequal Extended Joist Ends
    By Brockster in forum Revit Structure - General
    Last Post: 2006-05-30, 04:58 PM
