Summary: Make joist extended ends visible on coarse view.
Description: When a joist is added in plan and has a joist extended end it does not show the end in coarse view. If you switch to fine view it shows, but I don’t print in fine view. The only “work around” that I have is by adding a line to the end of the joist, but when you change the spacing all your lines are then off.
Product & Feature: Revit Structure
Submitted: Wed, 16 Nov 2011
