Thread: Revit should have a grade beam tool so it would schedule in the foundation category.
    Wish List Administration
    2011-08
    4,581
    Default Revit should have a grade beam tool so it would schedule in the foundation category.
    Summary: Add a grade beam category seperate from regular beams.
    Description: Revit should have a grade beam tool. This beam would be the same as a concrete beam but would schedule in the foundation category.
    Product & Feature: Revit Structure
    Submitted: Fri, 18 Nov 2011
    2010-09
    43
    Default Re: Revit should have a grade beam tool so it would schedule in the foundation category.
    I concur. I'm currently using concrete beams as grade beams. I don't have a problem with scheduleing because I usually have a schedule for grade beam alone. The problem I have is that I have to create a FIlter for Grade Beams so when I shade them not all my framing members are shaded.
    It's a work-around.
    2011-08
    4,581
    Exclamation Re: Revit should have a grade beam tool so it would schedule in the foundation category.
    Product and Feature: Revit Structure - Beams
    Submitted By: Shaun Peppers on Thu, 14 Jun 2012
    2011-08
    4,581
    Grade Beam Object Class
    Submitted By: Shaun Peppers on 11/18/2011
    25
    Could you modify the concrete beam family to be a grade beam and then put it into the Structural Foundations category so it would schedule with foundations??? Perhaps I'm making this too simple.
  1. 2013: How to cut out the top of a Grade Beam for 2x6 plate!
    By Cosmic Traveller in forum Revit Structure - General
    Last Post: 2013-04-11, 06:53 PM
  2. Bank Drive Thru Island Grade Beam
    By sachez in forum Revit Structure - General
    Last Post: 2011-11-11, 03:50 AM
  3. Model a grade beam and slab edge
    By jsoto1685 in forum Revit Structure - General
    Last Post: 2011-10-19, 09:09 PM
  4. Slab on grade foundation with infloor heat section
    By jeremyp444941 in forum AutoCAD 3D (2006 or below)
    Last Post: 2011-07-19, 09:19 PM
  5. 2011 Grade Beam Best Practice
    By ronsarlo in forum Revit Structure - General
    Last Post: 2010-10-28, 04:26 PM
