Thread: Converting a Survey from Metric to Imperial Units
    Active Member marble's Avatar
    2003-08
    Cincy
    53
    Default Converting a Survey from Metric to Imperial Units
    I have been asked to convert a survey from Metric to Imperial Units.
    I have been trying to find away and I think it is relativity simple, BUT it is eluding me. If anybody know a way please please help me.
    The Survey has 3214 points and was done by an outside contractor.
    I am working in Civil 3D 2011.
    2015-12
    Arizona
    2,478
    Default Re: Converting a Survey from Metric to Imperial Units
    I think one can export the points using XML
    then open a new drawing (from the Metric Template) set to the correct units and zone and them Import the XML file.
    I don't think you will need to result to using the data conversion tab of the drawing settings for this task.
    One question I would like to consider, do you have the survey txt file, and does it have line coding for figures in it?
    2003-08
    Cincy
    53
    Quote Originally Posted by mjfarrell View Post
    Having to convert from metric to imperial happens to me about once every 3-4 years it seems. I tried exporting the point using XML and after a little bit it worked. I am going to have to print this out and save it for the next time, 3-4 years down the road.
    Thank you for your help on this matter.
  1. Change Units From imperial to metric
    By GrD in forum AutoCAD Structural Detailing
    Last Post: 2013-10-12, 02:14 PM
  2. Converting Metric to Imperial DWG
    By spatterson in forum AutoCAD Civil 3D - Survey
    Last Post: 2010-10-05, 05:34 PM
  3. Converting file from IMPERIAL to METRIC
    By Openwheeler in forum AutoCAD General
    Last Post: 2008-07-18, 01:06 PM
  4. Converting Imperial to Metric
    By jbrazier in forum Revit Structure - Families
    Last Post: 2007-09-27, 08:05 PM
  5. Converting Downloads from imperial to metric
    By Kelvin in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-01-09, 08:00 AM
